Shortlist- Mobile
1221
10-05-2017 09:11 AM
RickeyFight
The mobile version of shortlist is a bit lacking. Especially on smaller phones.
Webapp Here
The information pane and the map are too small. The split screen is not working.
Is there a way to make the information pane slide up and down?
like this content pane:
https://codepen.io/mdshohelrana/pen/OPRYgQ
The bottom text also gets cut off when trying to scroll all the way down.
The bulleted theme has a nice mobile version.
Is anything like this in the works for Shortlist?
Story Maps
RupertEssinger
Esri Alum
Hi Rickey
Thanks for the note. There are some issues with mobile. On the UX front, we are looking at a new mobile UX that will eventually be used for the new generation of Map Tour and Shortlist apps. I can also repro that issue with the map extent being sometimes too far zoomed out and we have logged that one. Could you check to see if the issue with not being able to swipe to the bottom of the info panel is an issue with the version of your Shortlist hosted in ArcGIS Online? Your self-hosted Shortlist code is from the previous release and I think that is fixed now
Rupert
RickeyFight
here is the updated version
http://gis.ashland.or.us/cipshortlist2/
This also has some of my changes to the mobile version.
