Questions/suggestions for Cascade story map app
2913
06-17-2016 09:02 AM
C_EHoward
Occasional Contributor III
I like this new template but have several questions....
Will there be any tools to change the size, color of the text?Or should all of that be handled outside of the app, and then the text/code pasted into the story map? If so, will there be a way to show the HTML code as in other story map apps? I do not see any way to change the color of the title text on the cover page or any of the title areas.
Cover page - title required? I have an image I'd like to use as my cover & it has text, but I cannot save my story without entering a title.
Is there/will there be a way to have 2 media entries side by side instead of inline? Or other types of layout options?
The text box on the side of the 'immersive' is a bit too responsive IMO- the box does not appear until one scrolls the map and its a little distracting/misleading
Is this template available on Github? I don't really want to build a custom one (and I really can't with my skillset) but I hope to download the app & host on my server as with other story maps.
I do not see a way to get the 'view' options under the 'appearance' section of an added web map enabled- is this currently available?
with an embedded web map- the designer can decide which map layers to show but is that something the user can do as well? turn on /off layers?  How  about showing a legend?
Looking forward to this app's development....although I would have preferred a little more control over the look & feel as with other apps before this was made available. But maybe I am just not finding some of these tools!
thanks--
OwenGeo
Esri Notable Contributor
Hi Charlene, My answers in-line below:
Yes, we are definitely looking at more text formatting options like lists, colors, etc. for next release. Currently, any formatting will be stripped out when you paste text into your story.
Yup, I totally get that that. We'll consider hiding the title/subtitle on the cover as an enhancement.
That is available now for images. Insert an image, hover over it, then click the + in the lower right corner of the image. You can have up to four images in a row. We want to do more with this in future releases in terms of layouts.
You can try the other style of panel (fade) to see if you like it better. Click the gear in the upper right of the panel and select the option on the right under "Scrolling"
Yup, link is on the Cascade page on the story maps website or go right here: https://github.com/Esri/storymap-cascade
This works a little differently than Map Journal -- The buttons under View are for resetting anything you've changed in the map. If you move the map to a new location, change the visible layers (using the layer list in the upper right), or make a pop-up visible those changes are saved to that view of the map when you close the config panel by clicking the checkmark. If you want to undo anything you've changed you use the reset/clear buttons.
We are considering legends and features similar to Map Journal's main stage actions for a future release so that authors can design ways to help their readers interact with maps in a deliberate way.
I'm doing a series of blogs about Cascade and using its builder -- the first few are available already, more coming in the coming weeks. Story Map Cascade | ArcGIS Blog
Thanks for the feedback and questions!!
Owen
Owen Evans
OwenGeo
Owen
Owen Evans
C_EHoward
Thanks Owen- appreciate all the answers to my many questions!
