Problem with changing hyperlinks when uploading to ArcGIS Online
2031
08-14-2019 02:39 PM
DianeMastalir1
My goal is to simply create a story map tour which has a name and a description that can be clicked on to take the reader to a web page. I know it can be done because I've done it before. See:
https://www.wildlife.ca.gov/Conservation/Planning/NCCP/Plans
My core problem is that the links are changing when I format them as <a href...> and upload them to ArcGIS Online.
I Created point layer in ArcMap matching the map tour template and exported data to txt (csv) file. I then loaded the file into an ArcGIS Online map and shared the map as a story map tour. I created two different formats (well... more than that, but these were the essential formats). One had the description in simple http format and other included <a href...>.
Original ArcGIS Online Map document:   https://arcg.is/n0P0u
OPTION 1: Map Tour Data 3 - description in simple http format
Original description format:
https://www.wildlife.ca.gov/Conservation/Planning/NCCP/Plans/Riverside
Importing this as a csv file resulted in a layer in the AGOL Map that worked (appeared as "more info" link in pop-up and linked to the appropriate CDFW web page), but in the story map it appeared as text, not a link.
Link to Map Tour:
https://cdfw.maps.arcgis.com/apps/MapTour/index.html?appid=2dc323263c0a4d81aca7016888b60acc
OPTION 2: Map Tour Data 10 - description includes an href statement
<a href="https://www.wildlife.ca.gov/Conservation/Planning/NCCP/Plans/Riverside" target="_blank">More Information</a>
Importing this to a map as a csv file resulted in the link in the Description (in the pop-up) being changed to https://cdfw.maps.arcgis.com/home/webmap/viewer.html?useExisting=1,
which resulted in the web map simply being re-opened upon clicking on "More Info" in the pop-up. This carried through to the story map tour, except that the link changed to the link to the map tour.
Link to Map Tour: https://cdfw.maps.arcgis.com/apps/MapTour/index.html?appid=1e4562061e814f0881577ea520ed0a88
I have searched the web and this site and the help sites and either am having a unique problem or am using the wrong search terms. I'm hoping that there is a simple solution. I've attached the original csv files. Thank you.
Diane
Tags (3)
DianeMastalir1
I just wanted to update this. I contacted ESRI support and found out that I had somehow put extra quotes into the links (I calculated them) and that was causing the problem. User error, as it usually is. Thanks for the help!
Diane
MarkBockenhauer
Diane,
You could calculate the Description field to get it they way you want it.
On the 'Data' tab, click the description field and Calculate
Then using Arcade - calculate the field to be the HTML that you want.
var a = ''
a = '<a href="'+$feature["desc_"]+'" target="_blank">More Info</a>'
return a
Mark
DianeMastalir1
Diane
