Move back button?
4223
07-01-2015 12:36 PM
CMPDDGIS
Hello
I am using the Story map journal template.
I have the side panel on the right hand side.
When I load another item into  the Main Panel the Back button is positioned in center of the main Stage Panel.
This position covers up the title of some reports I have.
I wish to change the left parameter of the element to 10% but my customization is being over written.
What is the correct procedure for altering the parameters of the Back button?
Cheers
Johnathan
GregoryL_Azou
No, we still haven't made that configurable in the app, for the customization you need to use '!important' like
.mediaBackContainer {
  margin-left: -20% !important;
To be inserted after * CUSTOM CSS RULES */ in index.html.
Hope this will help you figure it out.
GregoryL_Azou
Hi Jonathan,
We will think about making this configurable. In the meantime, you should follow this guide to perform your css customization Esri/map-journal-storytelling-template-js · GitHub
CMPDDGIS
I was not able to get this work on my story map. Some other code seem to be overwriting my alteration.
Has this been updated in the core? If not could you please provide more details?
Happy to discuss
Cheers
Johnathan
GregoryL_Azou
CMPDDGIS
Thank you so much
