Map Tour loading failed
3759
05-13-2016 12:46 AM
JohnDuchneskie
I'm trying to embed this story map:
http://arcg.is/1NsFbcF
onto our website, here:
http://www.philly.com/philly/infographics/379315301.html
Sharing has been turned to public. But the embed only successfully loads on our website when I'm signed onto our ArcGIS Online account. And when it loads, it shows up in builder mode.
When I sign off of ArcGIS Online or StoryMaps, I get a "Sorry, Map Tour Loading Failed" message. Also, the embedded map on our website doesn't load in other browsers (I'm working on Chrome on a Mac).
So it seems like it's a sharing problem, but sharing has been set to public everywhere I look. Any suggestions on how to fix this?
John Duchneskie
The Philadelphia Inquirer
JohnDuchneskie
Yes, that was it exactly. The code I had embedded was this (offending code in bold):
<iframe width="100%" height="800px" src="http://inquirer.maps.arcgis.com/apps/MapTour/index.html?appid=d022e31881e54a8b8dbdaa100214bb79&amp;edit&amp;embed" frameborder="0" scrolling="no"></iframe>
I took the "&amp:edit" out and everything works fine now:
Map: PoliticalFest in Philadelphia
Thanks very much for your help,
John
TimWitt2
It works for me when I use the following code:
<iframe width="100%" height="800px" src="http://inquirer.maps.arcgis.com/apps/MapTour/index.html?appid=d022e31881e54a8b8dbdaa100214bb79" frameborder="0" scrolling="no"></iframe>
Maybe what happened is that the link in your embedded code looked like this:
http://inquirer.maps.arcgis.com/apps/MapTour/index.html?appid=d022e31881e54a8b8dbdaa100214bb79&edit=true
The &edit=true part will make it open in the editing mode which requires you to sign in.
I hope that is your issue.
JohnDuchneskie
John
TimWitt2
Glad I could help, don't forget to mark the answer.
