map layers not displaying
7370
05-10-2017 09:03 AM
ShannonGroff4
Hi there - I've created a story map (tabbed map series) that is looking at various demographics for a county that contains 973 census block groups. Each tab has a choropleth map focused on data by census block groups for a single attribute so each layer has 973 features within it. At first, I tried creating all the layers within one map and then for each story map tab, editing the tab to display or hide various layers, as I had read this is the best method for performance. This has led to some wonky display issues. Sometimes a layer will display and other times it won't. When I check my story map via My Stories, sometimes it does not show any problems with the layers/maps within the story map despite the fact that no data are showing and yet other times it will say there is an error with certain layers. I'm trying an alternative method to create a single map for each layer (which will then represent one tab in the story map) but so far this isn't fixing anything. I've tried saving the layers once symbolized; also tried setting a refresh rate (0.1 minutes). I've also tried viewing the story map with an https vs. http and that hasn't changed anything consistently. There doesn't seem to be rhyme or reason as to which layer will display and which won't. This story map is not public yet because it has to go through a process within our county prior to sharing, but I can't finalize it with these issues. Any advice? Thank you!
EDITED TO ADD: Also, sometimes the data will appear within the map (say, if I've symbolized the block groups by white race) and then it will disappear if I click on it to view the pop-up.
OwenGeo
Esri Notable Contributor
Hi Shannon -- Sorry you are having trouble with your story map. It sounds like you may be using very detailed features for your census block group layer. If there is a lot of detail in the features they will take a long time to draw or the request for the data may timeout. I'd recommend trying to generalize them using the Analysis tools.
If that doesn't work, I'd recommend contacting Esri Support for more help since you can't make your story public.
Owen Evans
OwenGeo
Owen Evans
