Little White Diamond Shaped question icons?
675
05-25-2014 08:52 PM
BenWard
When viewing a recently created story map, I noticed a little white diamond shaped question icon in the description text where an apostrophe was suppose to be. Does anybody know how to correct this issue and make it disappear?
RupertEssinger
Esri Alum
Sorry about the issue. It means there's a character in your data that the app can't display correctly currently. This sometimes occurs if text contains 'smart' or 'curly' quotes (apostrohope, single quote, double quote, etc) instead of 'straight' quotes. Those curly quotes are often found in text that originated in Microsoft Office apps. In your text you should be able to just selected the bad character, delete it, and replace with with a normal or straight character.
RupertEssinger
Esri Alum
It can also occur with certain accented non-English language characters currently. Sorry about the issue.
