Hi, working on my first story map. How can i get the main stage actions to allow me to locate a place on a map in my main stage? Basically i would simply like to have a photo or text auto pan to a location on a map in the main stage. Thank
That button should be right what you need. Creating Main Stage actions on image does not works well, in some case you can get it to work but I recommend you try on text first.
I cant seem to get that button to be available, always remains grayed out
Some of the button are only active when you have selected some text. Have you selected some text?
