How to use simple markers to show six categories?
6788
18
06-10-2014 12:46 PM
JulieK
how can I get the template of this playlist storymap( http://storymaps.esri.com/stories/2013/storylocator/ ) , this does exactly what I want?
The downloaded template  allows only four colored Markers and I want to use simple marker and show six categories or filters. How do I go about this? Please help!!
Can I get a template of the above storymap?
thanks,
Julie
JulieK
yes, I did modify so I could have 7 categories. Although I didn't change the symbols to simple ones instead I found additional number symbols . Download the additional symbols from here: http://downloads.esri.com/blogs/places/Numbered_marker_symbol_sets.zip
step 1: Once you have downloaded them move it to your playlist folder (playlist\source\resources\images\markers\indexed)
step 2: make changes to your mapconfig in the function getSymbolForDefaultRenderer(graphic,colorAttr,index)
if(graphic.attributes[colorAttr]){
  if (graphic.attributes[colorAttr].toLowerCase() === "b" || graphic.attributes[colorAttr].toLowerCase() === "blue"){
  iconURL = "resources/images/markers/indexed/blue/NumberIconb" + (index + 1) + ".png";
  else if (graphic.attributes[colorAttr].toLowerCase() === "g" || graphic.attributes[colorAttr].toLowerCase() === "green"){
  iconURL = "resources/images/markers/indexed/green/NumberIcong" + (index + 1) + ".png";
  else if (graphic.attributes[colorAttr].toLowerCase() === "p" || graphic.attributes[colorAttr].toLowerCase() === "purple"){
  iconURL = "resources/images/markers/indexed/purple/IconPurple" + (index + 1) + ".png";
  else if (graphic.attributes[colorAttr].toLowerCase() === "m" || graphic.attributes[colorAttr].toLowerCase() === "magenta"){
  iconURL = "resources/images/markers/indexed/magenta/NumbericonM" + (index + 1) + ".png";
  else if (graphic.attributes[colorAttr].toLowerCase() === "o" || graphic.attributes[colorAttr].toLowerCase() === "orange"){
  iconURL = "resources/images/markers/indexed/orange/NumbericonO" + (index + 1) + ".png";
  else if (graphic.attributes[colorAttr].toLowerCase() === "bo" || graphic.attributes[colorAttr].toLowerCase() === "bruntorange"){
  iconURL = "resources/images/markers/indexed/burnt_orange/BruntO_" + (index + 1) + ".png";
  else if (graphic.attributes[colorAttr].toLowerCase() === "y" || graphic.attributes[colorAttr].toLowerCase() === "yellow"){
  iconURL = "resources/images/markers/indexed/yellow/Numbericon" + (index + 1) + "Y" + ".png";
  else{
  iconURL = "resources/images/markers/indexed/red/NumberIcon" + (index + 1) + ".png";
  else{
Step 3: Add the additional color in your csv file.
I hope I have not missed but give it a try.
CONABIONC_for_Knowledge_and_Us
Thank you very much! However, it seems to me that just the first 4 colors in the list are respected (accordant to the max. number of the default template). Did you change something else in order to render the 7 categories you mentioned?
Kind regards
JulieK
Nothing else really   I did make changes in the index.html to modify the legend(see below). Did you build it to create a deploy folder or are you just previewing it?   Can you send me a screen shot of the windows explorer showing the path of the addition symbols and your mapconfig file?
// Legend names for playlist markers
  playlistLegend: {
  // Add a name for your playlist point layer to be used in the legend.
  "layerTitle": "Playlist Layer",
  // Choose to display your playlist point layer in the legend (true or false).
  "visible": true,
  "items": {
  "redIcon": {
  // Choose to display icon in the legend (true or false).
  "visible": true,
  // Choose the display name in the legend.
  "name": "Roads & Bridges",
  "iconURL": "resources/images/markers/indexed/red/NumberIcon1.png"
  "blueIcon": {
  "visible": true,
  "name": "Interchanges & Intersections",
  "iconURL": "resources/images/markers/indexed/blue/NumberIconb1.png"
  "greenIcon": {
  "visible": true,
  "name": "Parks, Recreation and Culture Facilities",
  "iconURL": "resources/images/markers/indexed/green/NumberIcong1.png"
  "purpleIcon": {
  "visible": true,
  "name": "Public Safety Facilities",
  "iconURL": "resources/images/markers/indexed/purple/IconPurple1.png"
  "magentaIcon": {
  "visible": true,
  "name": "Transit Projects",
  "iconURL": "resources/images/markers/indexed/magenta/NumbericonM1.png"
  "orangeIcon": {
  "visible": true,
  "name": "Sidewalks & Trails",
  "iconURL": "resources/images/markers/indexed/orange/NumbericonO1.png"
  "yellowIcon": {
  "visible": true,
  "name": "Health & Welfare Facilities",
  "iconURL": "resources/images/markers/indexed/yellow/Numbericon1Y.png"
JulieK
Also, did you add those color code alphabets in your csv file? did I mention that?
Thank you again! Yes I adapted the index.html and the csv-file. And actually it shows me 5 categories but "o", "bo" and "y" aren´t rendered. Here is my MapConfig.js:
  • define(["dojo/_base/array",
  •     "esri/symbols/PictureMarkerSymbol",
  •     "esri/renderers/UniqueValueRenderer"],
  •     function(array,
  •         PictureMarkerSymbol,
  •         UniqueValueRenderer){
  •     * Playlist List
  •     * @class Playlist List
  •     * Class to define a new item list in the playlist app
  •     return function MapConfig()
  •         var useDefaultRenderer = true;
  •         var maxAllowablePoints = 99;
  •         var markerPostionDefault = {
  •             height: 28,
  •             width: 22,
  •             xOffset: 3,
  •             yOffset: 8
  •         var markerPostionHighlight = {
  •             height: 34,
  •             width: 27,
  •             xOffset: 3,
  •             yOffset: 10
  •         var _tempRendererField;
  •         this.getMaxAllowablePoints = function(){
  •             return maxAllowablePoints;
  •         this.getMarkerPosition = function()
  •             return markerPostionDefault;
  •         this.getMarkerPositionHighlight = function()
  •             return markerPostionHighlight;
  •         this.getRenderer = function(layer,features,colorAttr,orderAttr)
  •             if (useDefaultRenderer){
  •                 _tempRendererField = layer.objectIdField;
  •                 var defaultSymbol = new PictureMarkerSymbol("resources/images/markers/indexed/red/NumberIcon1.png", markerPostionDefault.width, markerPostionDefault.height).setOffset(markerPostionDefault.xOffset,markerPostionDefault.yOffset);
  •                 var renderer = new UniqueValueRenderer(defaultSymbol, _tempRendererField);
  •                 array.forEach(features,function(grp,i){
  •                     if (i < maxAllowablePoints){
  •                         if (!isNaN(grp.attributes[orderAttr]) && isFinite(grp.attributes[orderAttr]) && grp.attributes[orderAttr] % 1 === 0){
  •                             i = grp.attributes[orderAttr] - 1;
  •                         var symbol = getSymbolForDefaultRenderer(grp,colorAttr,i);
  •                         renderer.addValue(grp.attributes[_tempRendererField], symbol);
  •                 return renderer;
  •             else{
  •                 // Add custom renderer
  •         function getSymbolForDefaultRenderer(graphic,colorAttr,index)
  •             var iconURL;
  •             if(graphic.attributes[colorAttr]){
  •                 if (graphic.attributes[colorAttr].toLowerCase() === "b" || graphic.attributes[colorAttr].toLowerCase() === "blue"){
  •                     iconURL = "resources/images/markers/indexed/blue/NumberIconb" + (index + 1) + ".png";
  •                 else if (graphic.attributes[colorAttr].toLowerCase() === "g" || graphic.attributes[colorAttr].toLowerCase() === "green"){
  •                     iconURL = "resources/images/markers/indexed/green/NumberIcong" + (index + 1) + ".png";
  •                 else if (graphic.attributes[colorAttr].toLowerCase() === "p" || graphic.attributes[colorAttr].toLowerCase() === "purple"){
  •                     iconURL = "resources/images/markers/indexed/purple/IconPurple" + (index + 1) + ".png";
  •                 else if (graphic.attributes[colorAttr].toLowerCase() === "m" || graphic.attributes[colorAttr].toLowerCase() === "magenta"){
  •                     iconURL = "resources/images/markers/indexed/magenta/NumbericonM" + (index + 1) + ".png";
  •                 else if (graphic.attributes[colorAttr].toLowerCase() === "o" || graphic.attributes[colorAttr].toLowerCase() === "orange"){
  •                     iconURL = "resources/images/markers/indexed/orange/NumbericonO" + (index + 1) + ".png";
  •                 else if (graphic.attributes[colorAttr].toLowerCase() === "bo" || graphic.attributes[colorAttr].toLowerCase() === "bruntorange"){
  •                     iconURL = "resources/images/markers/indexed/burnt_orange/BruntO_" + (index + 1) + ".png";
  •                 else if (graphic.attributes[colorAttr].toLowerCase() === "y" || graphic.attributes[colorAttr].toLowerCase() === "yellow"){
  •                     iconURL = "resources/images/markers/indexed/yellow/Numbericon" + (index + 1) + "Y" + ".png";
  •                 else{
  •                     iconURL = "resources/images/markers/indexed/red/NumberIcon" + (index + 1) + ".png";
  •             else{
  •             var symbol = new PictureMarkerSymbol(iconURL, markerPostionDefault.width, markerPostionDefault.height).setOffset(markerPostionDefault.xOffset,markerPostionDefault.yOffset);
  •             return symbol;
I found out that it works when I use
iconURL = "resources/images/markers/indexed/orange/NumbericonO1.png";
instead of
Also there seem to be seem inconsistencies in the markers´ names. Some start with 1, others with 01.
JulieK
Oh yes, I did rename first 10 images to fix that issue but I am glad you fixed that at your end.
Thank you again Julie - you made my week 😉
For the rest of us: if you want to activate the filter, put the name of the accordant column of your csv in the index.html here:
// Change name filter to match data
                filterField: "yourcolumnname"
muchas gracias!
JulieK
Wohooo...my pleasure:)
for the rest of us, the filterField is picky sometimes. It wouldn't take "Project Type" but accepted "projectType" to enable the filter.
