how to apply synchronization to only 1 tab
2932
03-07-2016 12:42 PM
Mattthew_Bare
Hi, I am using the synchronization option in story maps - series, but I seem to have a problem if I want some, but not all of the slides in the series to synchronize. Is this possible (hopefully without installing the API editor) ?
Similarly, can I apply the locator map to one slide but not all?
Both of these would be very helpful when making a story map that starts with an "overview" map and then zooms into to a specific location on the map.
RupertEssinger
Esri Alum
Hi, We don't offer either of those options in the hosted Story Map Series, but especially the first option would be a good enhancement. One thing you could do as a workaround is to create a Story Map Basic app for your overview map and then display that, using the &embed parameter to hide its header, in your Map Series:
http://www.arcgis.com/apps/StoryMapBasic/index.html?appid=a0a12caf5025441497d49d35b01a07f8&embed
OwenGeo
Esri Notable Contributor
If you are willing to customize the app you can apply the technique described in this blog post to add an index map.
There is also this example of a Map Series that has an index map as one of the tabs. The code for that is on the public Map Series repository on GitHub.
Owen
Owen Evans
Mattthew_Bare
I think I found an easier way of doing this - using a photo image of the “overview map” on the first tab of the story map, and then using synchronized maps on all subsequent tabs.
Matthew Bare
Sr. Associate, Evaluation & Research Program
Rainforest Alliance
2101 L St NW, Suite 440
Washington, DC 20037
Tel: +1 (202) 903-0776
http://www.rainforest-alliance.org/
