How to add search bar (geolocator) in Cascade story map?
1333
09-24-2018 06:31 PM
DeepakPuri
I've been trying to figure out how to add search bar in the map for the cascade story map.
I've already tried to add a story map with a search bar in the cascade story map. When I do this the bar at the top of the cascade story map cuts off the search bar!!.
I've been trying to to relocate the search bar, but read that it may be very hard to, and you'll need JS for that.
Anyone have any ideas?
Thanks!
AdrianWelsh
MVP Honored Contributor
Deepak,
Can you share your story map here?
OwenGeo
Esri Notable Contributor
Deepak -- If the search is hidden by the header you can add the app to a narrative section (as opposed to an immersive section). Choose a large size for the map if you want it to be the same size as it would be in an immersive section.
If you need to provide your readers with a map search for a map in an immersive section there are several configurable apps with search widgets that you can create and add to your story map such as Map Tools or Web AppBuilder. The header bar in Cascade shouldn't hide the search bar with these apps (for Web AppBuilder, you may have to change the layout).
Owen Evans
