would like to add a direction locator or direction to: in my story map....
Hi Dan -- what story map app are you using? https://storymaps.arcgis.com/en/app-list/
If Journal, Series, or Cascade, you can make an app with one of the other configurable apps like Web AppBuilder or Basic Viewer that have a directions widget. If you are looking to add directions to one of the other apps that can only be done by downloading the code and customizing the app to add that yourself.
Owen,
Thank you
Very helpful…. I think I may have needed to read a little further.
Thank you
Dan
