I would love to be able to select certain features of a layer to view and/or the layers themselves. Similar to Story Journal or Series.
Hi Casey,
Ok, gotcha. Unfortunately, Cascade doesn't support lists or tables at this time, but we are considering adding them in a future release.
If you have structured text you want to include in your story your options at this time are to either 1) create and host a webpage with your information and add that to a sequential section by inserting Media using the "Link to Content" option, or 2) enter and format your information in a word processing app like MS Word, take a screenshot, and add that image to your Cascade story.
It may help to work with your graphics department or someone with some design skills to create a table or infographic style display for your information.
Owen
Hi Casey,
Check out these "How To Cascade" stories, specifically the one on Multi-View Maps, for details about how to configure a web map differently in each view of an immersive section.
To show a subset of features you'll need to do a little work in your web map first. Edit the web map in the arcgis.com map viewer, copy the layer as needed, and set up a filter on the copy to show just the features you want. (Make sure your layer is published as a feature service since filters aren't supported on feature collections.)
Owen
Thank you Owen, that was very detailed information. I was wondering how to format the sequential section when I don't have a full paragraph but list of things I would like to display without adding multiple sections. Could you please advise me with this?
Hi Casey,
Sorry, I'm not sure I understand what you are trying to do. Can you provide a little more information and perhaps a screenshot or sketch of what you want to do?
Owen
Hi Casey,
Owen
