I would love to be able to select certain features of a layer to view and/or the layers themselves. Similar to Story Journal or Series.
Solved! Go to Solution.
Hi Casey,
Ok, gotcha. Unfortunately, Cascade doesn't support lists or tables at this time, but we are considering adding them in a future release.
If you have structured text you want to include in your story your options at this time are to either 1) create and host a webpage with your information and add that to a sequential section by inserting Media using the "Link to Content" option, or 2) enter and format your information in a word processing app like MS Word, take a screenshot, and add that image to your Cascade story.
It may help to work with your graphics department or someone with some design skills to create a table or infographic style display for your information.
Owen
Hi Casey,
Check out these "How To Cascade" stories, specifically the one on Multi-View Maps, for details about how to configure a web map differently in each view of an immersive section.
To show a subset of features you'll need to do a little work in your web map first. Edit the web map in the arcgis.com map viewer, copy the layer as needed, and set up a filter on the copy to show just the features you want. (Make sure your layer is published as a feature service since filters aren't supported on feature collections.)
Owen
Thank you Owen, that was very detailed information. I was wondering how to format the sequential section when I don't have a full paragraph but list of things I would like to display without adding multiple sections. Could you please advise me with this?
Hi Casey,
Sorry, I'm not sure I understand what you are trying to do. Can you provide a little more information and perhaps a screenshot or sketch of what you want to do?
Owen
Hi Casey,
Owen
Thank you.
