Solved! Go to Solution.
Patrick, as has been mentioned before, if you did not save your data as a feature service, all your data has been embedded in the web map. That being said, it is still possible to export it, it will just take a few extra steps.
Hi Scott
Seems very odd that after creating map from csv file, editing the story map with various collaborators, that u can not back save the final text, which has taken days to perfect, to a csv. This is a serious limitation of the story map creation process. In effect then all ur data is in the map... should anything happen u have to go back and start from scratch... with no backup document to work from. Does not seem well thought out process..... especially in a world where we are being told all the time to backup backup backup !
Stephen ... thanks a million for this work around... have map data in front of me at last
! Can throw away the 50 screen grabs I took to have text data to hand.... 1 excel much neater.
