Creating an Independent Copy from an Existing Story Map
4897
11-10-2015 07:33 AM
maryammashayekhi
We have a hosted Story Map (tour map) that we need to duplicate yearly and make some modifications to the content of the copy app. I used the ArcGIS Online Assistant to create the copy, but looks like that the text on the original app and the copy point to the same source. When the text is modified in one application, the change occurs in both apps.
The appID of the copy is different from the original when you create it through ArcGIS Online Assistant. I also changed the web map ID in the copy version. Can we separate the source of each app's content to make them independent from each other?
Thanks for your suggestions.
Tags (3)
RupertEssinger
Esri Alum
RupertEssinger
Esri Alum
