Creating 3D WebMap Journals
5031
03-19-2015 04:11 AM
IonutAlixandroae
Hello,
I saw this app ( http://story.maps.arcgis.com/apps/MapJournal/?appid=4c77a56bbcd743b69232cf3fd9c7a61c ) and I was wondering which are the steps to create a WebMap Journal but instead of having a web map, to have a scene?
Thanks !
Ionut
StephenSylvia
This app is actually pretty simple. Instead of loading a web map in the main stage, you should choose to load a web page. Then, you can embed the web scene into that section. We recommend using the “stretch” position when you configure the page. Also, unselect the “Unload when reader navigates away” as this will cause the scene to be reloaded every time you return to that section. One more trick, add “&ui=min” to the end of the web scene url so you don’t get the login banner on top. For example:
http://www.arcgis.com/home/webscene/viewer.html?webscene=91b46c2b162c48dba264b2190e1dbcff&ui=min
Instead of
StephenSylvia
Instead of
IonutAlixandroae
Thank you Stephen !!
RupertEssinger
Esri Alum
See also this blog post our colleague Bernie just published: Using 3D web scenes in Story Maps | ArcGIS Blog
