Click Feature to Open URL
12800
13
05-06-2015 02:12 PM
ChrisHolmes
Hello, I`ve downloaded a story map template to work with (just the one for single map). I`m wondering if there is a way to set it up so that when a polygon in a map service is clicked that a url can be opened (url is stored as attribute for that specific polygon). So far everything I`ve seen has to do with using the popup window to access information, I`d really like to be able to just click the polygon and have that url specific to that polygon open up.
Thanks for any help!
Tags (1)
AaronNepple1
Jai Siva‌ Thank you. This code worked perfectly for me. #javascript api 3.x
Does anyone know how to make the feature label a hyperlink as well?
-Aaron
AaronNepple1
If anyone is still having issues with the labels not being clickable, Robert Scheitlin, GISP‌ outlined a fix in this thread:
https://community.esri.com/message/720934-re-workaround-to-ignore-a-label-layer-when-click?commentID...
MarquesMunson1
I am trying this code for point features I have in an application I am building with JS 4.12.
  1. //Code for the specific URL to open in a new window
  2.   featureLayer.on('click',function(e){
  3.     var specific = e.graphic.attributes['SpecificAttribute']
  4.     window.open("http://YourUrl.com/"+specific);
  5.   });
How would this code work for a feature layer where the link is in the attribute field. I have it in a field called Link. Right now I have it shown below but it is not working.
  3.     var specific = e.graphic.attributes['Link']
  4.     window.open(specific);
  5.   });
PhillipSherman1
Do you know if it’s possible to add interactive arrows in ArcGIS Online web maps/apps? We have multiple facilities that accept different recyclable materials and our idea was to show an overview web map and have the arrows be clickable and interactive so that when a user clicks an arrow it takes them to a specific facility within the same app/map and so they can see the flow of materials from our county to the different locations.
