Solved! Go to Solution.
I am having the same problem that Lucinda encountered back in February, and the hotlink in Gregory's post ("This blog post") no longer seems active. Does that blog no longer exist, and if so, would someone mind explaining to me where I need to drop a logo to make it accessible for the Story Map? Can I not simply upload the logo from Picasa, as I did for the other story map images?
Thanks for your help.
Here is a link to another blog:
Customizing the Map Tour Story Map header and color scheme | ArcGIS Blog
This is specific to the Story Map builder mode, if you have downloaded and configured the web app it would not apply.
Thanks!
You can by switching to Builder Mode then in the Settings>Header of the hosted Story Map. From there you select Custom Logo and plug in the URL of the hosted image (flickr, facebook, any hosting site that provides a direct link to the picture).
Thank you both, I brought the logo into Picasa and extracted the URL by right clicking on the image and selecting "Copy Image URL"
