Caption turned off
2614
11-21-2013 12:02 PM
JosephCartier
Hello,
I am currently using Map Tour Template. Can someone suggest how I can remove the Caption that appears under the image ? Or at least have it minimized upon initializing the html.
thanks,
Joe
GregoryL_Azou
With the downloadable version, you can hide the caption hover the image using
<style>
#placardContainer {
 display: none !important;
</style>
If you don't know how to add that rule, look here.
RupertEssinger
Esri Alum
Try leaving the Name and Description fields blank. It will then give you no caption area so your image won't be obscured at all. This is especially useful if there is text in an image that you want people to be able to read without the caption getting in the way
JosephCartier
That looks great.  My problem is I like the caption under the Thumbnail.....I know I'm being particular.  lol  I was just hoping to diable the 'Captions' only.
Thanks.
GregoryL_Azou
<style>
#placardContainer {
</style>
JosephCartier
by inserting that code I was able to remove the caption portion!   Thank you very much!!!
JoeC
