Unfilled polygon symbology not maintained when exporting to KML
736
03-06-2018 12:49 PM
RobertNorheim
Unfilled polygons in ArcMap are filled in an exported KML.
Symbolize a polygon layer in ArcMap with a border only, and a null fill color.  Export with the Layer to KML tool.  Add the KMZ back into ArcMap and the polygon has a white fill.
The KML file has the tag
    <PolyStyle>
      <color>00ffffff</color>
rather than this:
    <PolyStyle>
      <fill>0</fill>
Documentation states that "The layer symbology will be used as the KML symbol." but this is clearly not the case.
Bug or feature?
Tags (1)
AgataZurek
Did you ever figure out a workaround for this?
