rounded data frame
8200
10
08-25-2017 02:27 PM
AlexM
I'm trying to create an inset as a rounded data frame within my main map.
I used 100% rounding for both my background and border to create a circular frame.
When I export the output map, there a square white border around my frame (attached image).
Is there any way to remove that?
DanPatterson_Retired
The technicial support article is here
 Data frame, inserted pictures, and inset map are not transparent on output
which contains work-arounds as well... but the biggest recommend is to use ArcGIS Pro to do your printing and export to PDF or SVG and not Illustrator
