MODEL BUILDER
970
12-12-2017 11:17 AM
ArmandoFreites
In a model constructor. what tools should I use so that the data of a specific field come out with two decimal points
DanPatterson_Retired
There are no tools in arctoolbox that do that specific task.
You would need to format your output in whatever mechanism you are using to produce output.
within text files you could round, truncate and a variety other things.
a = 1.23456789 .... python's   round(a, 2)  1.23  etc
So the important question is where do you want two decimals being shown... in the input? the output? and in either case what are they?
ArmandoFreites
Hellooooo, excelent.
But I have a one last problem with this, when the number is  1,101547, for example,    the outptu is 1,1, but I need: 1,10
How do I solve this?
again within text... getting the trailing zero on floats can be futile
a = 1.1011
"{:.2f}".format(a)
 '1.10'
