Map export error from ArcMap 10.4
1086
12-18-2019 04:01 PM
SlobodanKomatina2
I am trying to export a large map 174in x 96in from ArcMap. The map is really big so when I set this custom format from Print Properties and try to export the map I get the message:
"ArcGIS Desktop has encountered a serious application error"
and the application being closed. Why this happening and how to solve this problem? I just want to export this large map in PDF.
JimCousins
Do you have a license for Adobe Acrobat? If so, try printing to pdf instead of exporting.
If not, what is the resolution you are using?
Are you setting a background color? This will cause rendering of the entire page, so setting it to null may reduce the output size.
Do you have layers and / or attributes enabled under the advanced settings?
Is the background a raster? can you resample it to reduce file size?
Regards
Jim
