Can you have a projected coordinate system with WGS84 datum?
970
05-06-2023 01:03 AM
amrut627
Ok I am trying to wrap my head around one of the comments from my advisors on my thesis proposal. I note that all of my analysis are being done in the WGS84 coordinate system to ensure there’s no offset between images (I’m looking at both google earth imagery and another private sources imagery that are in WGS84). My advisors comment:
“This is the datum, but what is the projection? UTM?”.
I’m quite confused. Can and should I also have a projection in my project? I’m not sure how to set both a geographic and projected coordinate system?
DanPatterson
MVP Esteemed Contributor
from here
Coordinate systems, map projections, and transformations—ArcGIS Pro | Documentation
see the link in the above, under...
Download the list of supported projected coordinate systems.
and here
Download the list of supported geographic and vertical transformations.
... sort of retired...
