Annotation in a file geodatabase and subtype issues
281
06-26-2018 05:32 AM
PennySawyer2
Yes I have a couple layers that I have exported out of an sde database and I created a file geodatabase to create annotation labels within the database. Is there a shortcut to edit the labels or do I have to select each label individually to edit. Also, when I convert annotation for a larger layer for streets as a feature linked or append a overflow stack error pops up and I am missing a lot of street names. Finally,  When I convert layers from an sde database to a file geodatabase either the subtype is greyed out or I do not have the option to select a particular attribute field to use as a subtype.
