Adding pictures to ArcMap
2048
07-26-2019 12:16 AM
TomPiggott
Hi all,
I have encountered a slight problem that someone may be able to help me with. I am trying to add pictures onto my map to illustrate the views from certain locations. when i go to insert a picture that has been taken in portrait its the wrong way round. when i try to rotate it rotates the box but not the image.
I have attached an example of whats going wrong. the bottom left right picture is the original portrait photo. the one above is when I have tried to rotate it.
Is there a way to fix this at all?
Thanks
Tom
OwenGeo
Esri Notable Contributor
Hi Tom - This isn't a StoryMaps question, so I moved your question to a space where you're more likely to get a helpful answer.
Owen Evans
JosephCarter
You might do well looking into hyperlinking your pictures via an attribute table. . . .good luck! I have used this method in an historic bridge map successfully.
Joe
https://desktop.arcgis.com/en/arcmap/10.6/map/working-with-layers/using-hyperlinks.htm
JimCousins
Tom,
  You can open the picture in the standard windows photo viewer, rotate it if necessary, (although it rotated my test image for me) and save it with a different name. The photo should drop into your map with the correct orientation.
Regards,
Jim
