adding new rows to table
1448
02-04-2020 11:28 AM
AGOL1SMG
hello i'am new at arcgis and i'am stuck on adding data to my table.i have a table with retails in rows and theirs localisation in fields.i want to know how to add new retails to the table.i'am using arcmap 10.3
Tags (1)
DavidPike
MVP Notable Contributor
If you right-click on your table in your Table of Contents and select 'edit features' -> start editing.
if you now right-click and open up the 'attribute table' you will see your records.
scroll to the bottom of this table and there will be a blank row in which you can double-click and insert your data.
be aware this will not take on any location at this point.  if you are adding this as xy data you may be best to edit the table outside of arcmap and import as xy data.
AGOL1SMG
i will try this thank you
