Missing: A copy script has been created to make this process easier
1128
08-22-2021 06:09 PM
David_Wilton
In the readme for react it says a copy script has been created to make this process easier. But there is no reference to where this script is or where to get it from. The readme says to use create react app which obviously does not include this script.
I'm pretty sure the script should be something like this in the package.json scripts section
    "copy""ncp node_modules/@esri/calcite-components/dist/calcite/ ./public/assets"
https://developers.arcgis.com/calcite-design-system/framework-examples/react/
BenElan
Esri Alum
Hi @David_Wilton,
I apologize for the belated reply. In the documentation you provided above, under the "Installation" section, there is a link to a repo with sample apps. The copy script is in that repo here:
https://github.com/Esri/calcite-components-examples/blob/master/react/package.json#L23-L24
The copy script runs automatically after installing the node modules.
Ben
