Cannot align horizonally inside calcite-panel
1289
05-01-2023 01:48 PM
LefterisKoumis
I have two calcite-notice elements that I'd to display side by side (horizontally).
Both calcite-notices to be posted inside a calcite-panel.
The issue is that the notices are displayed vertically.
If I remove the calcite-panel tag, then the calcite-notices appear as intended, side by side.
The Calcite-panel doesn't allow horizontal elements?
https://codepen.io/lkoumis1/pen/KKGXNqv?editors=1000
@KittyHurley?
FC_Basson
MVP Alum
Try putting the panel content, i.e. the divs for each of the calcite-notice, within a single containing div, which acts as the panel default content container.
LefterisKoumis
Thank you. Yes, it does work if you place the notices inside another div , but it doesn't answer my question:
"The Calcite-panel doesn't allow horizontal elements?"
I used the panel in other scenarios, for example, where I placed a tab inside the panel. Several elements inside the tab were aligned horizontally with no issues. So, I guess the answer to my question is No unless if you use another component inside the panel and be the parent of the elements to be aligned horizontally.
