Non-consecutive Chips display in forward and backward selection
1266
12-12-2025 01:14 PM
Status: Closed
SebastianKrings
When using the selection-display=”fit” and selecting all but one values, the combobox correctly shows some values and the Plus-N-Chip.
When after that checking the very last unchecked value, the combobox shows the “All-Selected”-Chip instead.
When after that unchecking the last checked value one expects to receive the initial view where the combobox showed the some values and the Plus-N-Chip. Instead the combobox now shows only the N-Elements-Chip. It looks as the combobox would switch its mode from “fit” to “single”.
Expected behavior: Going back and forth between selecting all and less one should lead into the same outcome.
Actual behavior: Going back and forth between selecting all and less one leads to different outcomes related to different display modes.
Selection of all but one items
Selection of all items
After unchecking the last item
5 Comments
Sage_Wall
Hi @SebastianKrings , I'd suggest creating an issue on the Calcite GitHub site: https://github.com/Esri/calcite-design-system
Sage_Wall
Status changed to: Closed
SebastianKrings
@Sage_Wall
We initially created a support case against esri (#04066009). They asked us to create ideas instead.
SebastianKrings
SebastianKrings
removed wrong link
