Report URL returned is http
4257
05-05-2011 08:42 PM
PrashanthSukumaran
Now that the SSL cert issue is fixed.  I am facing a new one.  The response of the SummaryReportsTask is returning the url as http and not https.
  "results":
      "paramName":"Demographic and Income Report.PDF",
      "dataType":"GPDataFile",
      "value":
        "url":"http://domain.name/arcgisoutput/_ags_T4ABCE3C7542A58BEC092ED14D1309.pdf"
  "messages":
Since i have disabled http and enabled "Require ssl" in the IIS the http url is failing with a 403 - forbidden (which is correct and expected).
As a workaround I am currently doing a string replace to change the protocol to https.  Is there any configuration changes required on the sever so that the url is returned with the correct protocol.
by Anonymous User
Not applicable
What happens if you change the virtual output directory URL in the map service' CFG file to use https?
