Changing the BA Report Templates
2937
10-17-2013 06:15 AM
MattPohl
Hello-
I have successfully created a tool that uses the BA API inside a Flex application in order to retrieve demographic reports for user-drawn polygons. However the report template comes back as the standard ESRI formatted template (ESRI logo, BA Subscription hyperlinks, ESRI phone number, etc). Does anyone know a way on how to create your own templates and call them during the Get Report Templates task? It seems like this option should be available, but maybe it isn�??t? Any Insight on this would be greatly appreciated.
Matt
MattPohl
After a bit more experimenting I have been able to make changes to the report's header using some of the properties found in the ReportHeader class ie: logo, title, subtitle, etc. However, I am unable to remove any of the components in the footer such as the copyright, the BA hyperlink and ESRI's phone number. Has anybody been able to successfully do this? Or could someone point me in the right direction on if its even possible. I have attached a screen capture of the components I am referring to. Thanks in advance.
Matt
Jason_RobinsonRobinson
Matt
I believe that the intent is to not provide the ability to edit/change the footer information.  I know this has come up in the past so I will track down the official explanation/reasoning on that for you.
Regards,
Jason R.
