BAO Javascript API Benchmark Report on Ring Service?
2332
11-14-2012 07:21 AM
AlexandreLagache
Is it possible to get a Benchmark Report (or even a single Field value) instead of a Summary Report when using the Simple Rings Service?
[EDIT] That's on the RESP API, not the Javascript API...
Alexandre Lagache
TonyHowser
Esri Alum
Hi Alexandre,
Are you simply trying to access the underlying data in the report?
In that case, specify the output as Simplified XML ("S.XML" format instead of "PDF") and parse the resulting output from the Simple Rings service.
Tony
AlexandreLagache
Hi Tony,
That's what I've been doing, thanks.
But I was asking if it's possible to get a Benchmark Report or a single field instead of a Summary Report, in PDF or XML ?
I just want to see if performances are better...
Alex
