BAO Field Definitions
5913
11-28-2015 11:20 PM
RusselQuan
Does anyone where to find the BAO ACS field definitions?
I am doing an analysis on education and using the ESRI Business Analyst Online data which is derived from the 2009-2013 Population Age 25 or Older Educational Attainment data set.
The data that I am reviewing has stats for the following:
2009-2013 ACS Population Age 25 or Older by Educational Attainment: High School Diploma
2009-2013 ACS Population Age 25 or Older by Educational Attainment Base
2009-2013 ACS Population Age 25 or Older by Educational Attainment: High School Diploma (%)
Does anyone know how the Base number is determined?
The analysis shows a lower High School Diploma % in the higher Median Household Income areas of the Denver Metro Area, exactly the opposite of what I would expect.
I've done some research on this link, but cannot find a definition for the 3 attributes above.
http://www.census.gov/hhes/socdemo/education/about/index.html
Any help would be appreciated.
Thank you.
DanPatterson_Retired
I doubt the census uses Esri's field definitions.
The BA help is An overview of the Business Analyst Analysis toolset—Help | ArcGIS for Desktop
Where I found this link Updated Demographics—Esri Demographics | ArcGIS
Where I found this  http://downloads.esri.com/esri_content_doc/dbl/us/2015_US_Updated_Demographics_Data_List.pdf
which is probably what you want or on a distribution disk if so delivered.
RusselQuan
Dan,
Thank you for the research.  This is exactly what I was looking for.
Best Regards,
Russel Quan
