Transfer Values from Endpoint of line to connecting Point feature
2506
01-04-2021 06:41 AM
sjet1010
It would be nice to be able to set a calculation rule to pull data into a point layer from an upstream line layer. I want to pull the data from my upstream water / sanitary / and storm water lines and populate the downstream point layers. In attribute assistant you were able to do the to and from. Can you do that in attribute rule?
Tags (1)
Scott_Harris
This video is not exactly what you are asking for, but it might be a starting point for getting there: https://www.youtube.com/watch?v=ueckrlhto0Q
Learn how attribute rules can be used to automate attribution and copy attributes from one feature class to another. Download the sample project and data used in this video: http://ow.ly/W3Ea50B5Mnj For more information, please visit: http://ow.ly/4lrT50ANueJ ...
Scott_Harris
sjet1010
Thank you. Do you know of a way to possibly stake mulitple intersects into one attribute rule? Example, if the line end gets moved to different point feature layer.
