error 002846: the attribute rule type is not supported in the input workspace
That massage show when i creat anew validation rule
What's your input workspace type? Validation attribute rules are supported for file and mobile geodatabase, and enterprise Geodatabase that is branch versioned.
Can you zip up your GDB and share it so we can try?
Hi @waeltaher,
Thanks for sharing your geodatabase!
It appears that your data does not currently meet the requirements for implementing a validation attribute rule.2022-09-06_14-44-31.png
To implement a validation attribute rule, you will need to enable Global IDs and Editor Tracking on the data source(s). Here is a link to the documentation for reference:
Once these requirements have been implemented, you should be able to create and save a validation attribute rule.
