Re: Reporting data quality using Attribute Rules and Python
3762
8
08-30-2022 07:59 AM
waeltaher
error 002846: the attribute rule type is not supported in the input workspace
That massage show when i creat anew validation rule
JayCary
Does the dataset meet the requirements for using validation attribute rules?  Here is a doc topic that outlines the requirements for implementing attribute rules.
Tags (1)
waeltaher
the data set is center line ( polyline type ) it show the same erro although i try diffrent valaiation rules it show the same error massage , as showen in the picture blew .
LingZhang2
What's your input workspace type? Validation attribute rules are supported for file and mobile geodatabase, and enterprise Geodatabase that is branch versioned.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/validation-attribute-rules....
waeltaher
my work space type is file geodatabase
Tags (1)
waeltaher
MikeMillerGIS
Esri Frequent Contributor
Can you zip up your GDB and share it so we can try?
waeltaher
this is the DATA BASE
JayCary
Hi @waeltaher,
Thanks for sharing your geodatabase!
It appears that your data does not currently meet the requirements for implementing a validation attribute rule.
To implement a validation attribute rule, you will need to enable Global IDs and Editor Tracking on the data source(s). Here is a link to the documentation for reference:
Once these requirements have been implemented, you should be able to create and save a validation attribute rule.
