Is it possible to pass dataset name from variable?
4703
10
07-18-2023 03:26 PM
RhettZufelt
MVP Notable Contributor
I am trying to use a variable as the dataset name in FeatureSetByName, but not having any luck.
Like so:
 var table = 'TestTableName'
var tbl = FeatureSetByName($datastore,table, ['Year','AsBuilt'], False)
But, arcade doesn't like it.  I've tried several ways with no luck.  Hoping someone here know if this is possible, and how to do it.
R_
3 Solutions
MikeMillerGIS
Esri Frequent Contributor
That function requires a string literal, as ArcGIS needs to monikerize the class name when publishing to a feature service.
I typically use a switchyard function like the below:
function get_features_switch_yard(class_name, fields, include_geometry) {
    var class_name = Split(class_name, '.')[-1];
    var feature_set = null;
    if (class_name == 'PipelineDevice') {
        feature_set = FeatureSetByName($datastore, 'PipelineDevice', fields, include_geometry);
    } else if (class_name == 'PipelineJunction') {
        feature_set = FeatureSetByName($datastore, 'PipelineJunction', fields, include_geometry);
    } else if (class_name == 'PipelineAssembly') {
        feature_set = FeatureSetByName($datastore, 'PipelineAssembly', fields, include_geometry);
    } else if (class_name == 'PipelineLine') {
        feature_set = FeatureSetByName($datastore, 'PipelineLine', fields, include_geometry);
    } else if (class_name == 'StructureJunction') {
        feature_set = FeatureSetByName($datastore, 'StructureJunction', fields, include_geometry);
    } else if (class_name == 'StructureLine') {
        feature_set = FeatureSetByName($datastore, 'StructureLine', fields, include_geometry);
    } else if (class_name == 'StructureBoundary') {
        feature_set = FeatureSetByName($datastore, 'StructureBoundary', fields, include_geometry);
    } else if (class_name == 'Rules') {
        feature_set = FeatureSetByName($datastore, 'UN_5_Rules', fields, false);
    } else {
    return feature_set;
Jake_S
by Esri Contributor
@RhettZufelt what you're looking for is a build a dynamic query. In this post Building a dynamically FeatureSetByName query Hussein points out:
"FeatureSetByName does not support dynamic class names. The name of the class has to be available during static analysis of the script so we can build out the relations in the catalog. (E.g. if you copy Class A which has an attribute rule that reads from Class B we also copy Class B too)"
Not the best resolution but its confirmed by the Esri team
~ Jake
MikeMillerGIS
You can make this work, just need to build it like this
function get_fs(cls_name)
  return Decode(cls_name,
      "sdInlet",FeatureSetByName($datastore, "sdInlet", ['*'], true),
      "sdOutlet",FeatureSetByName($datastore, "sdOutlet", ['*'], true),
      "sdCleanOut",FeatureSetByName($datastore, "sdCleanOut", ['*'], true),
      "sdManhole",FeatureSetByName($datastore, "sdManhole", ['*'], true),
      null)
var fclist = ['sdInlet','sdOutlet','sdCleanOut',"sdManhole"];
for (var p in fclist){
    var point_fs = get_fs(fclist[p]);
    //Do stuff with it
alex_mapintel
I wonder if you need to wrap it as text using Text() :
var tbl = FeatureSetByName($datastore,Text(table), ['Year','AsBuilt'], False)
RhettZufelt
Thanks for the suggestion, I had not tried that.  But no, it validates, but give the ever so informative 999999 error when you try to save.
R_
MikeMillerGIS
    } else {
    return feature_set;
RhettZufelt
Thanks Mike,
This is very similar to the way I worked it out as well, except didn't wrap it in a function.
Want to choose a different 'input table' based on the user logged into Pro.  Was hoping there was a one liner to do this instead of a line for each 'option'.
R_
RhettZufelt
Is this still the case?  I wonder as in the AR editor in Pro:
var pfc = 'sdManhole'
var point_fs = FeatureSetByName($datastore, pfc , fields, true);
Is working perfectly, returning the values it should, BUT, will not let me save the attribute rule.
So, if FeatureSetByName needs a text literal (not template literal), then how is the above working as expected, just not able to save?
Any other ideas how to iterate through a list of layers like so?
    var point_fs = FeatureSetByName($datastore, `${fclist[p]}`, fields, true);
    //Do stuff with it
Thanks again,
R_
@Jake_S
Jake_S
by Esri Contributor
~ Jake
RhettZufelt
Thanks, that would explain why I couldn't figure it out 🙂
R_
MikeMillerGIS
      null)
    //Do stuff with it
RhettZufelt
Thanks @MikeMillerGIS , exactly what I was looking for.
Also, great use for the Decode function.
R_
