How to use model builder to apply an attribute rule to feature classes when table name is in the expression?
837
10-14-2022 11:03 AM
V1212
I am trying to apply an attribute rule to multiple feature classes using iterate feature classes in model builder. I get an error message because expression has a table name that's different to the name of the feature classes I'm trying to add the rule to.
ERROR 002717: Invalid Arcade expression, Arcade error: Table not found Table_4546, Script line: 2, SCRIPTEXPRESSION (row 2) [Table_4546]
Is there any in line substitution I can do to make it work?
Thanks in advance!
JohannesLindner
  • Get your Table name as variable (put "%" around the name in ModelBuilder)
  • Use Calculate Value
# Expression
generate_arcade_expression(%TableName%)
# Code Block
def generate_arcade_expression(table_name):
    return f"""
        var fs = FeaturesetByName($datastore, "{table_name}")
        var fs_intersect = Intersectcs(fs, $feature)
  • Use the output of Calculate Value as Arcade Expression for Add Attribute Rule.
Have a great day!
Johannes
