How to list existing Attribute Rules?
2353
06-07-2024 08:50 AM
Brian_Wilson
Honored Contributor
I wrote a script that exports rules from each feature class in a database, but it creates files even when a feature class has no rules.
I need to be able to tell if there are rules attached to a feature class, like ListFeatureClasses or ListDomains
There are methods Add and Alter rules but you have to know the name of a rule to do those operatoins.
How can I list??
Brian_Wilson
Honored Contributor
I found this old post in ArcGIS Pro by @JakeSkinner
https://community.esri.com/t5/arcgis-pro-questions/iterate-through-sde-to-find-and-export-fcs-with/t...
Seems I commented on it 2 years ago too!!
Short answer, there is an undocumented property when you do "Describe"
        rules = arcpy.Describe(fc).attributeRules
It returns a list of rules or an empty list of there are none defined on that feature class.
Brian_Wilson
Honored Contributor
SSWoodward
Wanted to share that attribute rule properties do have describe documentation going back to their implementation.  You can find it below.
Attribute Rules Describe Properties
