Flag row if any field has invalid domain values
1486
06-24-2022 05:12 AM
Bud
Legendary Contributor
I want to create a field that would flag a row if its values don’t match its domains.
Is there a way to populate such a field using an Arcade calculation attribute rule?
  • For each field, if the field has a domain, and if the value doesn’t match the domain, then set DOMAIN_VALUES_VALID to ‘INVALID’.
  • Hopefully, the script could be dynamic, rather than needing to hardcode a list of fields with domains in the script.
I’m aware that it’s possible to prevent invalid rows in the first place using a constraint attribute rule. That’s a valid option. But I also want to experiment with a flag too. Thanks.
Edit: Unfortunately, I forgot to mention that the table has subtypes (with domains).
JohannesLindner
Point FC with coded value domain ["Value 1", "Value 2", "Value 3"] on TextField:
Using CalculateField, I can insert other values (same works with arcpy cursors and attribute rules):
Calculation Attribute Rule on that point fc, field IntegerField, triggers insert & update
function code_is_in_domain(domain_dict, code) {
    for(var i in domain_dict.codedValues) {
        if(domain_dict.codedValues[i].code == code) {
            return true
    return false
var attributes = Dictionary(Text($feature)).attributes  // a dictionary
for(var field in attributes) {  // loop through the dictionary keys ( = field names)
    var domain_dict = Domain($feature, field)
    if(domain_dict != null && !code_is_in_domain(domain_dict, $feature[field])) {
        return 0//"INVALID"
return 1//"VALID"
(you could of course also populate a text field with that rule, or you could return booleans and use it as constraint rule)
I can still input values that are not in the domain, but now the flag gets set:
Have a great day!
Johannes
JohannesLindner
            return true
    return false
        return 0//"INVALID"
return 1//"VALID"
Have a great day!
Johannes
