FeatureSetByRelationshipName Attribute Rule Error
1874
05-31-2023 10:12 AM
Chip727
I'm trying to setup an attribute rule in ArcGIS Pro 10.9.1 that evaluates two GUID fields, crby_fpt_rel and crby_far_rel, in a sample point feature class for Null values. If both fields are Null, I would like Null to be returned. If either field is not Null, I would like to use the FeatureSetByRelationshipName function to pull the ft_alias from the parent feature class into the corresponding field. The sample point feature class is the child of two parent feature classes, feature_area and feature_point. The feature_area feature class is related (1:M) to the sample_point feature class using globalid/crby_far_rel; the feature point feature class is related (1:M) to the sample_point feature class using globalid/crby_fpt_rel.
The feature classes are all in the same EGDB. They are published to Portal as registered feature services, and used in Field Maps.
This is the script I built for use in the attribute rules for the ft_alias field. However, I'm receiving an error in Pro asking for an array or featureset for line 10 (var far = First(relarea)) or I get a 999999 error code. Additionally, Field Maps fails to submit sample points to the child feature class when the attribute rule is enabled.
var areaatt = $feature["crby_far_rel"];
var ptatt = $feature["crby_fpt_rel"];
var relin = "";
if ((IsEmpty(ptatt)) && (IsEmpty(areaatt))){
    relin = Null;
} else if (!IsEmpty(areaatt)){
   var relarea = FeatureSetByRelationshipName($feature,"EGDBName.DBOName.RelationshipName", ["*"]);
   var far = First(relarea);
   relin = far.ft_alias;
} else if (!IsEmpty(ptatt)){
   var relpt = FeatureSetByRelationshipName($feature,"EGDB.DBOName.RelationshipName", ["*"]);
   var fpt = First(relpt);
   relin = fpt.ft_alias;
} return relin
Tags (1)
HusseinNasser2
Hey @Chip727
Can you try to Exclude the rule from client evaluation and confirm if the error goes away?
Make sure this option is checked.
MikeMillerGIS
Esri Frequent Contributor
Are you edit done in ArcGIS Pro? Could it be the edit cache saving the edits till a certain time?
Chip727
Thank you for the response. I am using this in ArcGIS Pro. I'm not certain what you mean by the edit cache, but the attribute rule is set to trigger at insert. I still get the 999999  and 002717 errors despite how I set the trigger, insert or update.
HusseinNasser2
Hey @Chip727
Chip727
@HusseinNasser2 This worked! The attribute rule is now working when data is submitted from Field Maps. Thank you!
