Execute an attribute rule manually
7346
9
10-20-2020 01:56 PM
JoeBorgione
I think someone one showed me how to do this, but I just can't remember.  Here is my scenario:  I have an existing feature class to which I added a couple of fields.  Those fields are to be populated as a concatenation of some other field values.
What I did to run them manually was first set them for insert and modify.  Then I selected all the features, and in one of the fields I have the new concatenation rules set, I simple hit the space bar while in the selected attributes pane.  That's enough for a modification so both rules fired and I'm good to go.
However, that's sort of a hack; I thought there is a way to execute a rule manually without even making a phony modification.
That should just about do it....
HusseinNasser2
This is probably what you are looking for Joe, Batch Calculation / Validation Rules which can be executed through the Evaluate method in error inspector in Pro or through the REST end point.
Video here
https://community.esri.com/t5/attribute-rules-videos/create-publish-and-work-with-batch-calculation-...
DanPatterson
MVP Esteemed Contributor
Joe Borgione‌ are you talking about "Immediate Calculations"?
Calculation attribute rules—ArcGIS Pro | Documentation
... sort of retired...
JoeBorgione
Not exactly: these rules are specifically set up to fire when a feature is either added or modified so they fall in the class of Immediate Calculations.  Basically all the features are already in the feature class and I added a couple of fields;  I wrote the rules just to get some practice; I could have just used the field calculator, but where is the fun in that?
DanPatterson
Have you made a custom toolbox that performs the repetitive add fields, and loads your calculations that you use most often?  that would be fun
JoeBorgione
I asked around and there is no 'button to click' to execute an attribute rule on demand.  What was shown me was essentially the same thing I mention above: select a record and simply run a field calculation on the field with the rule and it will fire.
HusseinNasser2
Video here
LeonS
I am also looking for the ability to run an attribute rule manually.  I'm attempting to reproduce some of the rules I had set up using the Attribute Assistant in ArcMap, as I migrate my data editing to Pro.  I've found some particular rules executing automatically causes more problems than it is helpful.
I was beginning to look into the Batch Calculation, but it seems that only a workspace w/ branch versioning or FGDB is supported.  https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/evaluate-attribute-rules.ht...
I am working with an SQL Server geodatabase w/ "traditional" versioning.  Is this supported?  If not, is it coming?  Is setting up a feature service also a requirement?  There is just one editor, so these seems like an awful lot of overhead if I need to set up a service.
Edited -
I see that branch versions are only editable through a web feature service.  https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/branch-version-scenarios.ht...
Leon
TerriWaddell1
Just wondering if you'd ever gotten anywhere with running an attribute rule manually?  I have the same problem - - I used AUTONUMBER in Attribute Rules but under the manual option because I don't want every feature auto-numbered, just the occasional one.  I don't see a way to make an attribute rule when I only need to run it occasionally.
HusseinNasser2
The only way to run an attribute rule manually is to use batch calculation rule using Evaluate method.
For your use case however, I think you can still use immediate calculation rule and have a special field in the class (call it trigger (true or false)) when creating a feature have the trigger default to false and only when you flip the trigger field to true the rule can execute.
The rule will look something like this
if ($feature.trigger == 'true') return NextSequenceValue('seq');
return;
This is another way you can execute the rule manually.
JohannesLindner
Be sure to reset the trigger, else the sequence field will be calculated every time you edit it:
if($feature.trigger == "true") {
    return {result: {attributes: {trigger: "false", sequence_field: NextSequenceValue("seq")}}
return
Have a great day!
Johannes
