Attribute Rules Validation Error Numbers Reference?
1457
09-30-2022 05:42 PM
CarlVon_Stetten1
I'm working with the Utility Network solutions for Sanitary Sewer and Water.  I'm creating custom validation rules.  I found only one validation rule came with the Utility Network solution for Sanitary Sewer ("Device - Check Pipe Connection"), and it uses error number 5001.
Is there an Esri reference for validation rule error numbers?  Is there a recommended range of numbers to use for custom validation rules?
MikeMillerGIS
Esri Frequent Contributor
The error number is completely up to you.  I think we used errors in the 5000 range as they do not overlap with core error codes.
MikeMillerGIS
