Constraint or validation rule to check that text field matches a pattern?
465
07-08-2025 04:59 PM
AlfredBaldenweck
MVP Regular Contributor
Basically, I'd like to enforce a text field to follow a pattern like [A-Z]{4}\s{4}\d+, to use the regex for it. (Four letters followed by 4 whitespace chars, followed by 1 or more digits
Has anyone had any luck doing this?
2 Solutions
Jake_S
by Esri Contributor
@AlfredBaldenweck
Give this a go. I used this as the testing value
DDDD    1212121212
Arcade Constraint Rule: Checks if a field matches the pattern:
- Four letters (A-Z, case-insensitive)
- Four whitespace characters
- One or more digits
Usage: Replace $feature.Name with your actual field name.
var value = $feature.Name;
// Check if value is empty
if (IsEmpty(value)) {
    return false;
// Check length: at least 9 (4 letters + 4 spaces + 1 digit)
if (Count(value) < 9) {
    return false;
// Check first 4 are letters
for (var i = 0; i < 4; i++) {
    var ch = Mid(value, i, 1);
    if (Find(Upper(ch), "ABCDEFGHIJKLMNOPQRSTUVWXYZ") == -1) {
        return false;
// Check next 4 are whitespace
for (var i = 4; i < 8; i++) {
    if (Mid(value, i, 1) != " ") {
        return false;
// Check remaining are digits
for (var i = 8; i < Count(value); i++) {
    if (Find(ch, "0123456789") == -1) {
        return false;
return true;
JayCary
Not an Arcade-based solution, but the Data Reviewer extension's Regular Expression check can be used to create validation attribute rules to evaluate string formatting.
Jake_S
by Esri Contributor
@AlfredBaldenweck
DDDD    1212121212
    return false;
    return false;
        return false;
        return false;
        return false;
return true;
AlfredBaldenweck
This worked pretty well, but is unfortunately more involved than I was hoping.
@JayCary 's suggestion of using Data Reviewer also worked out ok, but has its own set of drawbacks.
Dropping this link to a relevant Idea Arcade: Regular Expression Support - Esri Community to add regex to Arcade.
Thanks!
JayCary
