Close parenthesis error when all others are closed
942
06-23-2025 10:03 AM
rsnider43
For this script right here, I am trying to get the endpoints of a new feature when it is created, then place a point on the end when it intersects with another feature of the same class that has a different value for the placement entry in the attribute table. So far the logic looks sound, but on line 14 I get a "Close parenthesis expected" error, even though there are no other open parentheses anywhere else in the script. Would this just be a weird syntax error?
var point_class = FeaturesetByName($datastore, "attributeruletest.sde.Riser");
var fibercable = FeaturesetByName($datastore, "attributeruletest.sde.Fibercable", ["placement"]);
function get_endpoints($feature) {
    var geom = Geometry($feature);
    if (Count(geom["paths"]) > 0) {
        var last_point = Point(Geometry($feature)["paths"][-1][-1]);
        return [last_point];
    return [];
var new_points = [];
var endpoints = get_endpoints($feature);
if (Count(endpoints) > 0) {
   if(fibercable =! $feature['placement']){
      for(var idx in endpoints) {
           push(new_points, {
               'geometry': endpoints[idx]});
if (Count(new_points) == 0) {
    return;
var edit_payload = [{
    'className': point_class,
    'adds': new_points
return {
    "edit": edit_payload
ZachBodenner
MVP Regular Contributor
Switch =! to !=
Close Parentheses errors occur even when that is absolutely nowhere near the actual issue. I do not know why and it drives me nuts.
Happy mapping,
- Zach
ZachBodenner
Switch =! to !=
Happy mapping,
- Zach
