Check $feature geometry type
1533
08-10-2023 12:25 PM
Jake_S
by Esri Contributor
I have code that reused on different feature classes that does a basic intersects functionality to retrieve field values and insert into the $feature. Yet the code should by pass some functions if $feature is a point feature class verses $feature being a polygon feature. Is this possible?
if (Geometry($feature)== "point"){
# do this
if (Geometry($feature)== "polygon"){
# do that
Something to that effect.
Thanks in advance
~JS
RhettZufelt
MVP Notable Contributor
Haven't tried it, but I think you could use Geometry type for that.
R_
RhettZufelt
R_
Jake_S
by Esri Contributor
Brilliant @RhettZufelt
ChristophKoschmieder
You could also use
Lower(Geometry($feature).type)
For me the surrounding "Lower()" was needed in order to get lower case results (e.g. "polygon").
For more information about the "Geometry" object and its properties:
Data Types | ArcGIS Arcade | ArcGIS Developers
