Attribute Rule to calculate Property ID for Meter record
1352
03-16-2023 11:23 PM
EstherSmith_Dev
I have a requirement to populate ElectricDevice (type Service Meter) record in Utility Network with the ID of the property it falls into. I thought I could use FeatureSetByName and Interects. However, FeatureSetByName ($map, <layer>) expects the layer to be in a same feature service. I cannot include property layer in the UN service. Is there any other way like FeatureSetByURL?
Cheers,
MikeMillerGIS
Esri Frequent Contributor
If the class is in the same database, you can use $datastore instead of $map
https://developers.arcgis.com/arcade/function-reference/featureset_functions/#featuresetbyname
  • featureSetCollection: FeatureSetCollection - The map or feature service containing one or more layers from which to create a FeatureSet. Typically, this value is the $map or $datastore global.
The other option is use a portal lookup to access another feature service
https://developers.arcgis.com/arcade/function-reference/portal_functions/
EstherSmith_Dev
HusseinNasser2
If you use FeatureSetByname with $datastore and exclude the rule from application evaluation, the rule should work on the server as long as the container (assembly I assume?) is in the workspace which it should be in case of the UN.
if those are related with containment associations you can use FeatureSetByAssociation
https://www.esri.com/arcgis-blog/products/utility-network/data-management/featuresetbyassocaitions-n...
