Arcade - 'System.InvalidCastException'
2421
9
08-23-2022 03:41 AM
girafee
Hello! I have an expression "var d = Dictionary('Accounting', $feature.AssessmentID)\r\nreturn d" and if the value is null, I get an exception:
Values = '((Esri.ArcGISRuntime.RuntimeDictionary<string, object>)result.Result).Values' threw an exception of type 'System.InvalidCastException'
I researched that I could write like this "$feature.AssessmentID +'' " and no exception. Any other options?
Thanks.
JohannesLindner
Hey!
This expression returns a dictionary. Are you sure you need a dictionary and not a string or something else?
What do you want to do with this expression? Is it for an Attribute Rule?
Have a great day!
Johannes
girafee
@JohannesLindnerI'm sure. I need to return the dictionary and work with it.
What options do we have?
JohannesLindner
You could return a json string representation of the dictionary:
return Text(d)
But the problem isn't with the expression. You want to use the output dictionary somewhere and that is what's causing the error.
Can you tell us what you're trying to do? If we know what you're working with and what you want to accomplish, it's much easier to help.
Have a great day!
Johannes
girafee
public override async Task ExecuteAsync(Feature feature)
Esri.ArcGISRuntime.ArcadeExpression ArcadeEvaluatorExpression = new Esri.ArcGISRuntime.ArcadeExpression("var d = Dictionary('Accounting1', $feature.AssessmentID)\r\nreturn d"); // AssessmentID = null
ArcadeEvaluator ArcadeEvaluator = new ArcadeEvaluator(ArcadeEvaluatorExpression, ArcadeProfile.FormCalculation);
List<KeyValuePair<string, object>> profileVariables = new List<KeyValuePair<string, object>>();
profileVariables.Add(new KeyValuePair<string, object>("$feature", feature));
ArcadeEvaluationResult result = await ArcadeEvaluator.EvaluateAsync(profileVariables);
Dictionary<string, object> retValues = JObject.FromObject(result.Result).ToObject<Dictionary<string, object>>();
if (retValues != null)
   foreach (KeyValuePair<string, object> pair in retValues)
   feature.SetAttributeValue(pair.Key, pair.Value);
JohannesLindner
The Arcade expression returns a Dictionary, but it seems like JS can't convert that.
Sadly, I have no idea about the JS API. You can probably get some help in the ArcGIS API for JavaScript - Esri Community
Have a great day!
Johannes
girafee
I want to have a null check in my expression and if it is null, return null as a string: "var d = Dictionary('Accounting', $feature.AssessmentID)\r\nreturn d". For example: "if($feature.AssessmentID == null) $feature.AssesmentID = 'null'".
Thanks.
JohannesLindner
Like this?
if($feature.AssessmentID == null) {
    return "null"
return {"Accounting": $feature.AssessmentID}
Or do you want to set the value in the table to "null"?
Have a great day!
Johannes
girafee
Hi! Could you please help me? I have the same problem and I don't know how to solve it. I need to return dictionary from Arcade Expression, and work with it. But if at least one value is null, I get an exception and can't work with other values.
Esri.ArcGISRuntime.ArcadeExpression ArcadeEvaluatorExpression = new Esri.ArcGISRuntime.ArcadeExpression("var d = Dictionary() \r\n if($feature.AuthorizationNotice == null) \r\n { d['QuantityActual'] = $feature.Status \r\n d['Assessor'] = $feature.DueDate \r\n return d}"); // $feature.DueDate = null
ArcadeEvaluationResult result = await ArcadeEvaluator.EvaluateAsync(profileVariables); // here we have System.InvalidCastException
JohannesLindner
In fact, it's exactly the same problem, this is your thread...
Sadly, I'm as unqualified as before. I don't know anything about JS. I guess you couldn't find help in the JS Community?
I am qualified to look at your Arcade expression (it's different from the one you posted earlier), and I'm not sure what you're trying to achieve.
if($feature.AuthorizationNotice == null) {
    return d
Here's what your expression does:
  • if AuthorizationNotice is null, return a dictionary
  • if AuthorizationNotice is not null, return null
Is this the intended behavior?
Have a great day!
Johannes
